Insulating a single brick wall without kingspan
2 Jan 2014
Northumberland
Hello i have a single brick build detached garage at the back of my garden i have put in stud work at 75mm width for the walls with the intention of using kingspan but its biblically expensive so i was wondering what else i could use theres a semi permable membrame facing the walls followed by insulation (kingspan or not) followed by plastic non permeable membrame followed by plaster board i am using jablite 100mm for a floating floor and was going to use 100mm kingspan in the roof but i am trying to save money with the walls dont want to use jablite wondering if 75mm rockwool slabs are ok ? Cheers
Try celotex or similar. Most seem to be cheaper than kingspan.
Thanks for the reply im looking on line and celotex and kingspan are approx £9 per square metre so i was wondering if there was an alternative to the extruded pir board or whatever these are cheers
Cheers thanks for that so really it need to be kingspan just hunt around for broken and cheaper stuff cheers
My builders used Quinn Therm for my loft, so I assume that must be another cheaper option.
I honestly have no idea how these prices compare, but I am guessing these pallets are cheaper than buying off the shelf
http://www.ebay.co.uk/bhp/quinn-therm
Check these guys out as well. Rockwool will be chaeper, but it won't give you the same warmth as celoted type stuff does.
Work out the payback period for the price of the insulation and the cost of heating the garage. You probably don't want the scimp now and pay more in heating it.
Celotex is about twice as good for the thickness than polystyrene or wool, but about ten times the price.
If the rest of the detailing in the garage is really good it might be worth the celotex
