Hi there,
I’m currently renting a mid-terrace house with some friends. The top floor consists of two attic rooms and a landing, which are all freezing. Both bedrooms have access to the eaves, and after crawling around inside, it turns out that most of it is uninsulated, apart from about 30mm of poorly installed fibreglass in some places.
I am considering buying some kingspan and getting a professional to do the entire sloped roof, from the bottom of the eaves, to the apex. The issue is, that there are two large sections of skeiling at the front and back of the room, about two metres from top to bottom. The rafters are about 75mm deep, and sit directly on the plasterboard underneath, so after leaving a 50mm air gap for ventilation, there will only be space for about 20-30mm of kingspan, which will be difficult to install given the size of the section.
I’m wondering if 30mm of kingspan will make any discernible difference to the temperature of the room. There is more space to work with in the eaves and space above the rooms. Would it be worth putting 30mm of insulation in the skeilings, and adding another layer of kingspan in the eaves and top space, or is insulation only as effective as its weakest point?
My other consideration, is installing kingspan inside the room and painting over it, but given that my housemate on the top floor isn’t as bothered about the cold as I am, I doubt he would want to lose the headspace, and doing this to one room would be pointless.
I would very much appreciate some guidance with this, as I am completely amateur in this area. Is there another solution that I’m missing?
Many thanks is advance,
Josh
Josh
