Insulation behind Plasterboard
3 Jan 2007
We've taken the bathroom walls back to the brick to board and plaster over. I was planning to line the walls will the thermal foil type of insulation and board over the top.
I've since found that there are 'Insulation Plasterboards' available - which would be best for keeping the heat in the bathroom??
use inso' backed boards. thes can be fixed using dry wall adhesive.
make sure you stack them flat prior to dabbing them to the wall as a bowed inso' backed board is a 'mare to straighten out.
