Hi I am moving on with my project and having never done anything like this before have some questions I hope someone can answer.
I need to fix insulation boards direct to the walls then add battens to this to provide a 25mm gap before attaching the plaster boards.
my questions what's the best way to fix the boards direct to the wall, I have seen dry fix (pink Grip) but should I use something else.
Also once this is fixed how do I fix the battens these are 25 mm thick and going into a 50mm insulation board do I mark up the wall and put raw plugs in ?
some walls ( the new ones ) are block work and some brick.
thanks any advice appreciated.
Cliff
Cliff
