Insulation on blockwork wall
20 Mar 2006
Cambridgeshire
I have a garage with a single skin block wall between it and the kitchen. Obv no insulation in the wall so was thinking of installing celotex or rock wool onto the garage side and then battering between and covering with ply or OSB so I can hang stuff without drilling thru the insulation.
So first question is will this actually work in stopping cold coming thru garage wall and into kitchen
And second, is it ok for insulation to be against the block wall and then covered or does there need to be some sort of air gap?
18 Mar 2017
Wales
You might want to edit your thread title (although it does attract attention as is :) ).
26 Aug 2016
Yes that would work is basically external wall insulation, although internal to the garage
