It's down to risk, really.
Both rooms are very high risk
Yes if one is burning then you still have one route that's not burning.You can only take one route at a time, no matter how many options
Logically it is, but Not according to the approved documents definition, and the reason an inner room is so defined because of the risk of a fire in that other room, you need to be able to jump out the window. But you can just use the other door in that case, unless you're meaning that a fire in one room would make a fire in the other room more likely to be impassable. High risk is in terms of tiny percentages.a room is still an inner room regardless of the number of exits if you must pass through another room.
The proposed set-up is not acceptable.
Simple solution is to stick a window in the back.
there are no options for access for these two elevations (private land / someone’s back yard).
