Intercom Bell system 801wired to electric gates
15 Jan 2017
Any ideas as to which terminal number the following wires should goto?
Red
Black
White
Green
White with blue
White with green
That needs a good clean ?
Are you wanting to connect a new intercom to your gate controller?
Or is it existing?
It's existing and stopped working on looking inside the box the wires listed are not attached
The intercom will have the lock release wire connected to the gate open trigger ?
Don't think inter com wired into gate controller from your photo
You will have another power supply to the intercom else ware
Its almost impossible for us to tell you what colour wire will go into what terminal as we don't know anything about the terminals or where those wires go. Those colours sound like telecoms cable, do they go to a handset or to the gate intercom? If so can you take a picture of the wiring inside that?
Also can you provide make/model of the controller, intercom/handset etc...? We can probably dig out a wiring guide for you then.
20170115_145424.jpg 20170115_145614.jpg 20170115_145155.jpg 20170115_145244.jpg 20170115_144942.jpg 20170115_144921.jpg 20170115_144854.jpg
I would start at the relay in picture 4 as the bell system handset does not have a voltage free contact , it supplies 12ac to the relay when the button is pressed
What is the problem ?
No speech on handset ?
Does not open gate ?
Handset dead ?
Does it ring ? If not check AC power supply , the old ones did have a 1amp glass fuse inside the psu housing
