Possibly. Does anyone know what is (or may be) inside those plastic housings? Are they perhaps spring-loaded push-in connectors (like in our 'MF' JBs), with the screw bits at the end for strain relief?An in-line version of wire nuts!
It does sound as though it's something like the spiral spring in Wire Nuts, although whether each conductor is held in a different part or the conductors overlap and it tightens around both simultaneously isn't clear,Ease of Installation: The Melni connector is easy to use. Just insert the stripped cable, twist the end caps to tighten the patented spiral insert, and then tighten the waterproofing caps.
According to the web site the product is "in development" designed to make joins in ROMEX® brand NM cable - seems to be US stuff.Doubt that's a "real" photograph, the cpc is at least as heavy as the line cores
Well, I can't cut the sheath that neatly.Doubt that's a "real" photograph, the cpc is at least as heavy as the line cores
Or possibly not.Possibly.An in-line version of wire nuts!
Dunno about those small ones, but the big ones are like this:Does anyone know what is (or may be) inside those plastic housings? Are they perhaps spring-loaded push-in connectors (like in our 'MF' JBs), with the screw bits at the end for strain relief?
That picture certainly looks like a graphic representation, but yes, the ground wire in NM cable is the same size as the other conductors in sizes up to 10 AWG. This example (hastily stripped to show the construction, hence not a nice neat trimming of the sheath!) is #12 size:If you Google NM cable you'll see that all of the cores appear to be of equal csa.
Is that not what "possibly" means?Or possibly not.Possibly.
