- Joined
- 14 Dec 2020
- Messages
- 2
- Reaction score
- 0
- Country
First time poster with limited plumbing experience - go easy on me
We're doing a loft extension, and will have an internal soil stack serving a ground floor, first floor, and loft toilet - the 3 toilets are pretty well aligned. The soil stack will be 'boxed in' on the ground floor and first floor.
Should we:
A. Also 'box in' the soil stack in the loft, as it travels to vent to the roof? The problem is this box would be in an ugly position in the loft shower-room. We want to avoid this option if possible.
B. Hide the soil stack within the stud wall in the loft, as it travels to vent to the roof? This stud wall is being built as part of the loft extension. The stud wall could be made wider than usual (20, 25, even 30cm) to accommodate the soil stack, and would not compromise the appearance of the loft shower-room (it is nice and wide, so we don't mind losing some width). This is our preferred option. However, we've heard the noise from the soil stack might then transmit around the house - is this a big problem, and can this be avoided with good insulation, or even boxing it in within the stud wall etc?
C. Rather than venting to the roof, vent to the loft shower room using a Durgo/AAV? I'm not sure this would look any better than option A. Plus I don't like the idea of having three toilets venting to an internal space!
We will have a builder and plumber helping us, but having advice will help us plan at this stage. Any advice much appreciated!! Thanks
Should we:
