I agree, but obviously the OP is needs reassurance. The on-line calculators may come up with less.This is hilarious! why the detective work? the OPs exisiting boiler is already 12kw, if that one heats the house ok then so will the new one!![]()
Did you take the proposed double glazing into account?Thanks guys for your input, used the sedbuk website and it came out to just over 15kw.
In that case a 15kW boiler sounds too big. I suggest you try the other calculator as the Sedbuk one can be confusing.House is 15 years old and is very well insulated and stays warm.
Windows are currently old wooden frame double glazing but these are being updated to upvc and i took this into consideration on the sedbuk calculator.
Do you use Firefox or some other browser, i.e not Internet Explorer? The EST calculator seems to have a problem if you do. I have emailed EST and they say there is nothing wrong!Right, the other calculator doesnt work when you click next.
You are not the first! The EST calculator more user friendly.I made an error on the sedbuk calculator the first time round with the number of exterior length walls and height too!
Taken a long time to confirm the obvious, but I hope it was worth it.So did it all again and looks like 12kw will be fine with double glazing, cavity wall insulation and sufficient loft insulation.
Both online calculators already include the 2kW for the cylinder in the result, so there is no need to add it a second time.2kW has to be added for water heating.
So a 15 kW boiler would seem to be the right power.
