Bathroom fans are motors,
Now you are being silly.
In my youth I was cleaning the bathroom extractor fan at the girl friend's parent's house when ever helpful mum put the light on so I could see better.
, it's either that or in the last 2 months you've been in the CU and changed the MCB.
and the plumber put it on a different circuit?
I don't follow. What is that regulation?So yes technically the fan within the oven does require a local isolator and it seems a bit silly [and somewhat difficult without rebuilding the oven electrics] to not include the whole appliance.
Ok. Not very - what's the word - conclusive?Silly or not I'll stand by that interpretation.
No it doesn't. If the manufacturer is demanding something which is not required by the regulations, then that something is not required.Regs also say to heed the MI's which my interpretation comes down to: if the manufacturer states it requires local isolation, then it will be fitted incorrectly without it acording to regs whether regs require it or not. However if the MI's contradict regs then it becomes somewhat difficult.
There is a very obvious reply to that.In my youth I was cleaning the bathroom extractor fan at the girl friend's parent's house when ever helpful mum put the light on so I could see better.
Does post #1 give 2 examples where the regs require MI's to be followed?No it doesn't. If the manufacturer is demanding something which is not required by the regulations, then that something is not required.
Oven manufacturers who state the oven must have a 16A fuse so whatever you do it will not comply.
I'm not aware of a cut off point for the isolator but over 370W there is a requirement to install proper motor OCD. This reg is, like so many others, totally ignored by thousands of people.I have said no, it does not rotate, and no longer do you need to follow manufacturers instructions, you only need to take them into account.
Mothers house there was an isolator behind the hob, and the sub consumer unit was next to back door which was also in the kitchen, clearly if some thing goes wrong better to isolate as you leave the house than reach over a hob. Seem to remember 350 watt limit on a motor before local isolator, but not heating element.
You haven't thought that through, have you?Rather worrying that 54% of replies don’t know the regs. Who’d trust an electrician?
No.Does post #1 give 2 examples where the regs require MI's to be followed?
Because it is not necessary.Yes I have seen the oft quoted MI. So why can a 16A fuse not be fitted?
Are you disputing the existence of the quoted text?
So what's the alternative?Because it is not necessary.
Because it would mean fitting an unnecessary accessory.
Because you don't have to.
Because it would be silly.
