Why would winston want an isolator, he doesn't believe in them
Why would he even have an FCU, thought he relied on the internal fuses, I am 99% sure I recall.
TFFT!!!!i guess we will never see ( a video of ) winston1 naked and wet at his consumer unit turning OFF the power to his smoking electric shower.
Winston.Not local to the shower.
It does have a switched FCU as it is otherwise on a 16A circuit.
winston1 said:It does not NEED an FCU. What about if it is sold in mainland Europe where FCUs are not used.
We also know that in most other countries it would be wired direct to a 16 amp MCB.
If it is on its own MCB you don't need a FCU. Just size the MCB correctly (6amp).
... the boiler which will have its own internal fuse...
Are you a sparks? Ever heard of safety?
As the boiler and CU are only a few metres apart there is no need for a FCU or switch. The MCB will do for both. Ignore any rubbish by the boiler manufacturer saying a FCU is required. Boilers are sold all over Europe where FCUs are not available or compliant. Boilers have internal fuses for protection.
Yes. Because it is on a 32 amp circuit.Winston.
Why have you got a FCU for your boiler?????????????
Why on earth have you not removed it and why did you allow it to be fitted in the first place?????
Regs or not, safety and common sense come in to it too.Rather worrying that 54% of replies don’t know the regs. Who’d trust an electrician?
Should have defined 'required' in the original poll question, then.Regs or not, safety and common sense come in to it too.
Yes, but it is not required by the regulations.My interpretation of 'a safe way of isolation' is most easily provided by fitting an isolating device, such as a socket and plug or a multipole switch.
OK. Is that not a safety or emergency switch?In the past I've encountered a 'special case' as the regs do 'require' a local isolator for a motor.
Now you are being silly.Bathroom fans are motors, Fan ovens contain a motor as do the washing machine and dishwasher, Rotisories contain a motor, fridges contain a motor, Pond pumps contain a motor, as does the sewing machine, Our ceiling fan is built around a motor, Central heating pumps are motors and of course modern boilers contain motorised fans, Heck even my laptop contains a motor, in fact several...
So in my opinion a FAN oven requires a local isolator.
OK yes I am highlighting some of the situations which do seem to be bizarre and I've deliberately added some which would not generally be considered.Yes, but it is not required by the regulations.
If it is required by the manufacturer for no valid reason then it is wrongly required .
