I realise that this is a bit of a long shot but has anyone ever changed the drive-belt on a Hayter Harrier 41 petrol lawnmower (or other similar Hayter model) or is anyone familiar with how their auto-drive systems work ? The ones in question are the ones driven by a pulley attached to the side of the engine (so not the models driven by belts within the mower, above the blade).
My Harrier 41 is the 306R which is a 20+ year-old model which has a V-belt, driven via a pulley on the side of the (Briggs & Stratton) petrol engine - the pulley comes in two halves (separated by washers) and is fixed to the pulley drive-shaft via a bolt.
Basically, the two pulley halves on my machine are loose and I could do with knowing whether this is normal before I attempt to reinstate the belt (the mower doesn't currently have one fitted as I cut it off a good few years ago). As far as I know, the belt I removed was original (so the auto-drive system has never been interfered with), plus the bolt that holds the pulley halves and washers in place is as tight as it will go.
Here's a short video to show how loose the pulley halves are :
I guess it's possible that the V-shaped belt will push down into the cavity between the two halves of the pulley when the auto-drive is activated, pushing them apart and making everything tight, but I'm not familiar with this type of system so don't know if the looseness is intentional or not.
If anyone familiar with this type of set-up can give me the benefit of their experience, I'd really appreciate it. Cheers !
