Is changing a flue on 7th storey possible?
11 Jan 2012
London
Hi, question for an old friend who lives on a tower block, 7th storey.
His boiler was fitted 25 years ago and keeps breaking down.
In those 25 years, external insulation has been added to the building and a recessed alcove left where flue is.
Now he wants to change the boiler and before getting quotes, wants to have some understanding to avoid scams.
Questions: 1. Can a new flue be fitted without access to the outside?
2. If not, can existing flue be re-used? Maybe buying same brand boiler? (Worcester Bosch)
3. At the moment he has a green star 24kw junior serving a one bedroom flat, one shower, 4 radiators. Should he go for same power? More? Less?
4. How much is roughly a combi if new one is installed in the same spot?
5. Release valve (I think that's how the curved copper pipe is called) is not as I always seen them.
It starts as a copper pipe, going into plastic solvent weld and connected with the 40mm main kitchen waste. Of course that can't be going outside, but is this setup ok?
Thanks.
