Is IE the only browser that fully supports Hikvision NVR?
30 Mar 2015
I can bring up the login page and access menus e.g. Config, in all the browsers I have tested but the viewing/playback only seems possible in IE. I assume this is because it needs the Active X control but wanted to check if any other browsers are supported.
I am aware of the Mobile App for remote viewing.
Unless I am mistaken, Microsoft seem to be favouring Edge and I wonder if IE will be around much longer...
OMG I hope this is not the case, if so that's me never ever able to use Hika gear.
The issue is viewing the live feed, you can do this in other browsers with limitations or addons but messy to be fair, and seems to be more problematic above 2MP resolution on live feed.
as for IE its still available
From a Microsoft Support site: Internet Explorer 11 is the last major version of Internet Explorer. Internet Explorer 11 will continue receiving security updates and technical support for the lifecycle of the version of Windows on which it is installed.
I am hoping that Hikvision are working on supporting other browsers
ie Tab is a simulator for ie settings basically under 2MP you can usually open in other browsers, or that's what I see
The IE chrome extension no longer works for me and IE support seems to have ended.
View and Playback is still not supported on Edge or Chrome.
Are there any workarounds for viewing the cameras via the web please?
The mobile app is still fine.
