I'm currently doing a renovation to my under stairs ground floor toilet. Last week I had the plasterer in and I have noticed that he had rotated the waste pipe where it disappears through the chipboard subfloor 180 degrees to allow him better access.
I am not really sure how the waste pipe is connected under the floor, but I had presumed that the waste pipe would be solvent welded and shouldn't really move (the connections above the subfloor are solvent welded).
Is it normal for the pipe to be able to twist? It requires a little force, but moves fairly easily. In a way it makes life easier as I can move the pipes to suit the install when I get everything connected back up, but I am a little concerned that the twisting might be a sign of a possible issue in the connection under the floorboards.
