Is it ok to install a new shower over a hole in the wall
9 Mar 2025
Would it be safe to install a new electric shower over this or should it be repaired by putting a new tile over it?
I need a new electric shower installed. It could be installed and sealant used around the outside, but that the warranty for the shower would be void and water could leak behind the wall.
Is it a fair assumption that the safest option is to have the hole filled properly before fitting a new shower?
Have a look at this old thread of mine:
See also “similar threads” below.
You can bodge it and risk leaks, the ceiling below getting soaked and falling down.
Or
You can do it right.
A couple of tiles, some adhesive and some grout will not be expensive but can save you hundreds if the top option is chosen.
Thank you for the replies.
I don't think I will install a panel behind it as not keen on how it looks. I will look into tiling over the weekend to see if I can do it myself.
