Is it worthwhile retro insulating a porch?
13 Feb 2012
Sussex
View media item 42740Hi All
I've just registered and tried to put the picture of our porch on here, so here's hoping it's ok...
I wonder if anyone can help with an opinion as to whether it's worth putting loft insulation into the porch (2.5 m x 2.5 m with a conventional tiled roof).
There is currently a upvc ceiling which has been fixed to the roof joists and cross timbers somehow. Unfortunately no insulation was put into the roof void 7 years ago when it was built and I'm wondering whether it would be worth doing it now. It seems to be a question of how much heat loss is there through the roof, the windows (DG but all round) and the floor (concrete and uninsulated).
Our front door is oak panelled, about 60 years old and I fear, leaking heat from the house.
I have just received a quote of £130 to take down a couple of lengths of this upvc (each length is about 30 cm wide by 250cm and it fits together like tongue and groove I think) and put in the roll of insulation (which I already have).
Before anyone asks, at the time the porch was being built, my dad was critically ill in hospital and I really didn't give the porch much thought....
My husband, who is not a great DIYer, thinks the benefit won't be worth the expense.
I'd be grateful for your thoughts.
Thank you!
Zoe
[/img]
Hi All
I have just received a quote of £130 to take down a couple of lengths of this upvc ....
Thank you!
Zoe
[/img]
Your husband is right - the price is too high also . The guy probably didn`t want the job so priced it to make it worthwhile . The oak door will be fine - try another builder if you want stuff done . I know a few trades in E. Sussex :wink:
I would say that there is no advantage if it is a porch - ie separation from the main house via a front door
Even if not, the amount of glass would mean that heat loss through the roof is not much of an issue
If there needs to be work done to the ceiling anyway, then yes fit the insulation as part of that work, otherwise there will be no payback on the £130 costs of the work in terms of energy savings, and probably none in terms of comfort either
Nice porch by the way.
It's a pity they never factored in a small soffit when building the roof.
Still looks right for the house though.
I've lost count of the amount of porches i have seen that are simply wrong. Some people just don't realize that a front porch is the first thing people see and a poorly designed or built porch can ruin the look of a house.
Ho hum.
assuming it has no heating the difference between the outside and inside will be quite low so the heat loss around 20% off not a lot
the savings may be as much as 1p a day or even per week
insulation will only stop the movement off heat so on a sunny day will reduce the porch heat gain from the sun
the most heat gain is from making sure that only one off the doors is open at one time :D
