The Barrister could not remember exactly what happened to the builder but thought he only got a fine of a few hundred "because he did not realise the danger involved".
The filling loop is the braided flexible hose that fits between the cold main and the heating return pipe under the boiler.
It should have 2 isolating valves, the non return valve should be on the cold main side and the flexible hose disconnected unless the system is being filled/topped up. The quality loops have end caps to prevent accidental leaks if the valves are meddled with.
I cant see any picture of a filling loop.. As for proping up a flue and CO leak. I would like to know what boiler an what flue system before i believed it
Quote Going back to the original question .Providing the appliance is working right the products of combustion are water vapor and carbon dioxide not monoxide which as we all know is lethal. It is not ideal that it occasionally comes back in through window but providing boiler is set up and working correctly it`s not going to do you any harm.
As for the distance from flue terminal to a raised non-combustible surface ie the brick wall in your photo most new worcesters state 500mm . But some manufacturers never used to have this distance in there instructions and have been adding them over the past few years as roof termination becomes more popular. There is talk of roof termination becoming compulsory with the obvious exemptions.
Thanks a lot for your advice and taking the time to reply.
Would a Carbon Monoxide detector help up in the loft just in case the boiler developed a fault? Would one be affective if it is blown through the window?
