- Joined
- 21 Dec 2015
- Messages
- 8
- Reaction score
- 0
- Country
I bought this house two years ago. It was built in 1892. Tonight I was in the living room. I noticed for the first time that the plasterboard had moved away from the external wall (inside the house but this wall is an external wall) and oddly there was a draft coming into the house. I tore away the crumbling plasterboard. I used a clothers hanger that I had straightened out and probed the wall. To my shock I found a small opening between the bricks and without too much force the full length of the hanger went through the wall. It must have come out on the other side - outside the house. I haven't been out to check as it is late and that side of the wall is boundary with the neighbour's land. I can't make sense of this as I have little knowledge of these things. I can only guess the mortar has become weak between the bricks but what is the implication of this for me? Do I need to rebuild the entire wall. I think the wall is a cavity wall. So if the inner brickwork is weak like this then I expect the external skin must also be weak. How do I fix this problem? Will the wall collapse if left like this?
