I keep my heating on 24/7 and controlled to 20.0 degrees. This way, my system only ever needs to raise the temperature by a maximum of 1 degrees. (1 degree differential on the room stat) This way, my boiler spends about 3 hours within a 24 hour period on, and the rest off.
My gas bills are low as opposed to people's who have the heating on for a couple of hours in the morning and 5 or 6 hours in the evening bringing the house back up to an acceptable temperature again.
Let's assume that you are being truthful about the burn time of your boiler. (Which is very very unlikley)
In your example your boiler only burns for 8 minutes every hour to maintain a constant 20C +/- 1 totaling 3 hours in a 24 hour period.
If the OP was to set timer to ON 06:30/OFF 08:30 allowing a constant 30 minute warm up period and the 12 minutes ignition for the other 1 1/2 hours that's a total of 42 minutes of the boiler running.
Back on at 16:00 and off again at 22:00 again allowing a 30 minute warm up period and 44 minutes for the other 5 1/2 hours that's a total of 74 minutes
Total boiler ignition time in a 24 hour period is 116 minutes or 1 hour 56 minutes so a whole hour and 4 minutes less then your way saving a 1/3 on the energy usage.
All the above assumes a fixed Kw being used by the boiler.
Now add into the equation these supposed expensive pointless controls that will incorporate weather comp and open therm technology that will modulate the burner while running to adjust flow temperature and adjust the warm up period to take into account for ambient temperatures that saving will only increase further probably in the region of an additional 5 - 10%
All the above is obviously only a paperwork exercise and there are too many variables but you can see how wrong you are with your assumption that running 24/7 is a better way of doing it.
@garmcqui If you could get a 400mm x 1600mm in there that would push you up to about 2.1Kw
Jon
Say I have two leaky buckets.
I give one to bhm1712. He keeps it always full to the brim, with constant topping-up.
I give another to garmcqui. He fills it to the top, waits for it to empty, then fills it again.
Who uses the most water in the long term?
Jon
...but it isn't working...because his room isn't achieving the temperature he requires in the set time period....
I would also estimate that if you have an intelligent thermostat, it would be more efficient with constant heating.
Threads like this are great because they help you work out who is worth listening to and who can safely be ignored.
No, not telling - but it should be fairly obvious; you can see who "liked" my bucket post, for example.
Wrong.to say it's more expensive goes against the physics...
But with an intelligent thermostat they are aware of your away periods and turn the heating off only coming on at a certain time (or geo location) before you return depending on the internal temperature, ambient outside temperature and required set point.
Yes you are right that heating should be set to constantly on if you have an additional timer in conjunction with it but ideally the timer will be removed so that the smart controls can take full control of the system.
Jon
But your bucket analogy doesn't hold water (pun intended)
