I'm installing a cooker hood with a sheet metal chimney to cover the ducting. I don't want another unsightly switched FCU on the wall above the worktop. The hood has its own on/off switch. What are my options. I don't understand rules about having a separate switch and it being accessible (why do I need a separate switch if the fan already has one?).
a) Can I hide it behind the sheet metal chimney? This would be my first choice. (should be safe enough since all the fan wiring is separately enclosed and not accessible when chimney is removed)
b) Can I put it in a surface mount box under the wall cupboards behind the pelmet where you won't see it? If so, are there special rules for the twin and earth that will emerge from the wall and run under the cubpoard?
c) Can I put it under the worktop in the base kitchen units? Or maybe above the wall cupboards where it won't be seen?
Thanks in advance for any advice.
