    Dismiss Notice
Is there any way 1 person can instal a Concrete Fence?
Discussion in 'In the Garden' started by BathDIY, 17 Sep 2020.
  1. BathDIY
    BathDIY
    23 May 2017
    177
    Thanks Received:
    2
    Country:
    Looking to instal a 2-panel fence, 2 meters (finished hight) with concrete posts.
    I like the idea of this method as the grave board will retain a portion of my back garden, so with one hit I retain the earth and instal the desired fence.
    I'm assuming that the posts and gravel boards will be too heavy for an individual to manage. Or perhaps there are methods I could use to do this safely by myself?
  2. Sponsored Links
  3. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,516
    Thanks Received:
    550
    Country:
    Unlikely, unless you are built like a brick outhouse.
    It's theoretically possible using builders' trestle but would be a killer
    Gravel boards are really heavy and the amount of extra kit would cost more than paying a guy to help
    • Thanks Thanks x 1
  4. BathDIY
    BathDIY
    23 May 2017
    177
    Thanks Received:
    2
    Country:
    I was afraid of that thanks, will come up with another plan.
  5. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    18,830
    Thanks Received:
    2,085
    Devon
    Country:
    150mm high ones are about 30kg so I'd say it depends how well you are built.
  6. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,516
    Thanks Received:
    550
    Country:
    Sorry- I just re read this!
    I read it as a whole fence constructed out of gravel boards.
    I imagined trying to get a 2M high wall built on your own
    Yes you can manoeuvre 12" gravel boards on your own but it's hard.
    I have used concrete fence posts and boards.
    It's easier to use a post, add a gravel board as a spacer, add panel, second post. Use postcrete and have a couple of spare bits of wood as braces until the cement dries.
    If you are lucky you can do it without cutting anything - if you do cut, you will need an angle grinder for the concrete and steel. Easier to cut the last one before the second to last is fixed.
    • Thanks Thanks x 1
  7. BathDIY
    BathDIY
    23 May 2017
    177
    Thanks Received:
    2
    Country:
    Thanks for your thoughts Tigercubrider, in that case, will give it a go.
  8. Sponsored Links
  9. mrrusty
    mrrusty
    1 May 2018
    255
    Thanks Received:
    60
    Country:
    Yes, I've done it, and I'm not built like the proverbial. Sack barrow, etc. and some bars to help move stuff in to position. As has been said post, then gravel board, then post etc.
    • Thanks Thanks x 1
  10. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,516
    Thanks Received:
    550
    Country:
    How much needs to be retained?
  11. BathDIY
    BathDIY
    23 May 2017
    177
    Thanks Received:
    2
    Country:
    Not much 20 to 25cm
  12. Tigercubrider
    Tigercubrider
    22 Jul 2016
    3,516
    Thanks Received:
    550
    Country:
    • Thanks Thanks x 1
  13. Celeronmanuk
    Celeronmanuk
    29 Nov 2019
    137
    Thanks Received:
    27
    Country:
    I can do 6" gravel boards and 8ft posts fairly easily by myself if that helps.
Loading...
Share This Page
