Hi everyone.. apologies if this isn't the right forum but it seemed the best fit.
I've just new joists and new floor boards put down in my house, along with a new kitchen window and window sill being fitted, and the walls plastered.
Now I'm no expect (and why I'm asking you guys!) on what's acceptable or not but I'm getting earache at the moment from the misses and things don't look that right to me either, but if they are then fair enough.
Anyhow...
The new floor boards are showing splits in them. Is this normal or should I get my builder to sort it out? The old boards that came up had been in for 50+ years and didn't have any in... (reason for new ones were some joists were rotton and needed replacing).
The boards aren't all level either. What I mean by that is if you run your finger across one board to another then there is a ridge on some of them. Others it's smooth.
The window sil that's been put in has been done after the plastering and you can see a 1 - 2.5mm gap around the edges where it meets the wall. All my other window sills look burried into the plaster and I would have thought this one should be too. I suspect if I mention it to him he'll just put sealant round or something but it doesn't seem quite right to me.
As for the plastering parts of the walls are smooth, others not - has it not been polished correctly? There are also a few scratches - tool marks? - on the surface too and in one area it has an obvious bump where it goes from one piece of plaster board to another. Again is this acceptable? I told the guy I was painting onto the plaster directly before anywork was started and that was the reason why I wanted nice flat, perfect (if you can have such a thing) walls.. but as it is I think you'll still be able to see the marks even after I've painted them.
So should I leave it and pay him the rest of the outstanding money or ask him to correct it?
Thanks guys.
Anyhow...
Thanks guys.
