Is this cable OK for maglock and keypad?
17 Jul 2017
I am looking to install a electromagnetic lock, controlled by a keypad, and two exit buttons, and a buzzer.
I have the setup working with a bench supply at moment and the lock, along with the keypad is drawing 0.55amps @ 12v.
I need 6 wires for the keypad (12vin, 12vout, gnd, opensw and 2 bell terminals) and I am going to run separate cables from each item and the power to a central junction, to make further customization easier.
The magnetic lock is a monitored model, with 5 terminals.
I was planning to use this cable for the lock and the keypad. Maximum run for each cable will be 2 metres. Is it a reasonable choice?
https://www.screwfix.com/p/time-white-8-core-alarm-cable-25m-coil/394jy
I could use 6 core right now, but 8 may give me some further flexibility.
Any thoughts much appreciated.
Only a DIY'er, but I'm pretty sure that will be fine!
0.58mm2 is about 20AWG which has a current carrying capacity of up to 1.5A.
Although it's worth finding out the current draw of the maglock.
As you have the spare cores available, I would consider doubling-up the cables to the power connections on it - just to be sure!
I hope that makes sense! :)
