Almost 4 years ago, my mother had a new condensing combi installed to replace her 25 year old glowworm balanced flue cast iron boiler. She had hoped that it would be more efficient. However, after 3 full heating seasons she's noticed that the new boiler pretty much consumes that same quantity of gas as the old one!
Installed in a bungalow, the flue is vertical and goes out through the roof. However we have never seen it "plume" which I believe it should when condensing. Could there be something wrong with the boiler that prevents it operating in condensing mode?
The boiler was installed and is serviced by BG (after they told her they couldn't get parts for the old one) and generally works OK otherwise. It is a Gloworm CX which she chose because her original Glowworm had never failed or needed new parts in 25 years. Unfortunately the new one has failed twice already, once rather spectacularly by filling the kitchen with smoke due to an internal electrical fault.
She has 6 radiators in a 1980's bungalow with insulated cavity walls and has the heating on all day. 21 degrees in the lounge and bathroom 18 everywhere else. Piping is copper microbore in the loft space with runs down to the radiators embedded in the walls.
If you concentrate hard, in very cold weather, there is a slight hint of a "plume" when operating in hot water mode.
We find it strange that a modern high efficiency boiler (A or B rating?) is consuming the same amount of gas as a "G" rated one. any ideas?
