£50 per fitting seems a bit OOT seeing as you are supplying the fittings.
However,
you say that this is in a sloped ceiling, is it going to be plasterboard - joists - roof felt - tiles?
If so then the builder will also be fitting insulation between the joists to comply with part L of the building regs. As recessed downloghts require some breathing space around then the insulation around the fittings will need to be removed, if it is removed then it will no longer comply with part L....
so the builder might have to find some other way to comply with part L and give you the lights that you want, he may have to add a false ceiling or he may do it some other way..
another consideration of Part L of the building regs is that 1 in every 4 fittings must produce 40 lumens per watt, i.e. be energy saving - how is this going to be complied with??
AND finally - as the builder is doing the work and is probably subbing out the electrics if you want the recessed lights you will either have to pay, negotiate or make do with what was on the original plans.
However,
