One of the isolation valves underneath my boiler has developed a leak, and the pressure drops regularly due to this
What's the best way to change it - drain down the primary system - and what type of valve can I fit - will a 22mm ball-o-fix compression swap be ok? Probably need to alter pipework slightly if new valve longer or shorter?
Thanks for your help all
