I foolishly didnt notice the arrows on the isolation valves when connecting the water supply to my basin. They are both facing the opposite way of water flow
I've fitted a new tap and the water pressure from the tap is much lower than the old one. Will this be a direct result of the valves facing the wrong way? I thought they were just open/closed?
I also noticed that the flexi's that came from the tap were a much smaller diameter than the old setup so the reduced flow could be the design (it's quite a shallow basin).
They were push fit so turning them round means water off again, some cutting and new valves
