Isopon Filler
19 Jan 2006
Wiltshire
I just wondered if anyone has used Isopon P40 as an adhesive?
I have just bought a Honda Civic & the plastic trim over the arches has some broken clips leaving it looking a bit uneven & scrappy.
I bought some dedicated spoiler adhesive, but the cure time is well over 24 hours (I need to use the car more often).
I know that P40 is not the easiest stuff to use, but it cures very rapidly.
Any thoughts or other suggestions?
TIA
Filler sticks like hell to anything so I guess it would do what you want.....you'd have to move smartish though to get it into place before it starts to go off! You'd need a fair quantity too.
An easier product could be a seam sealer or even silicone if you could tape it in place, but I don't know the curing time.
John :)
Excellent product, it will work as long as the trim has a rough enough finish to grip.
A lot depends on the grade of plastic. If the trim is ABS (quite hard) and the surfaces are roughed-up, it might work. If they're polyethylene or polypropylene (bendier and worse surface finish than ABS) , it's not likely work for long.
