Johnson and starley
22 Jul 2017
My mother has a Janus 3/3/30 which she uses for hot water only.
Today her hot water cylinder ran dry because her wc was overflowing . Wc since fixed. Since then the pilot light has gone out on the Janus, is that a safety feature because of no hot water, didn't have time to sort it this evening but hopefully it will relight in the morning?
15 Aug 2010
Livingston
Cant see how the WC overflowing would cause the HW Cylinder to run dry ? and cant see even if it did that the pilot to go out, do you mean the cold water storage tank in the loft ran dry ?
22 Jul 2017
Ian, when the wc was fixed the hot water tank possibly plus the cold tank took a long time to fill up.
I think that when the wc was overflowing someone had a lot of hot water use and because water was pouring out of wc overflow it wasn't filling hot water cylinder.
That's my theory. Could be wrong of course
15 Aug 2010
Livingston
No the HW cylinder would still be full unless you drain it from the drain point, cant see how the two incidents are related
22 Jul 2017
Sorry, I think I made it sound complicated.
The mains wc was overflowing.
I think that someone may have left a hot tap running as well ( I don't live there) just my ancient ma and her visiting carers.
This caused the hot and cold tanks to run dry.
So the question was, could it have caused the warm air boiler to shut down as there was no water to heat in the cylinder.
6 Jun 2018
Buckinghamshire
Unless the feed to WC has been taken from the cold feed to cylinder (teed off @ lowest point).
The cylinder would be the direct type if coupled to a Janus.
The CWSC is possibly slow to fill in which case the WC cistern ran the cylinder dry (no gravity circulation through the Janus).
22 Jul 2017
That sounds right GG. The wc is 1 floor down from the HW cylinder.
So if the Janus had nothing to heat in the HW cylinder what would happen?
22 Jul 2017
Ok, so I have downloaded the user instruction guide tonight , do u reckon I will be able to relight it tomorrow, all looks a bit fidley
