Hey guys
I have recently bought a CCTV system, but I made a mistake and used the pre-cut cables for the cameras which you can buy from eBay and it turns out that some of the cables are slightly shorter than the length required so I need to increase their length by about by maybe 70 or 80cm.
Inside these cables there are three very thin wires and another much thinner wire which isn't coated, they are all coated with an aluminium foil(I guess).
My question is how do I extend these cables?
The wires inside the cable are very thin and fragile, what sort of stripper should I use?
Many thanks in advance
