Hi - first poster here and looking for some advice on joining an existing concrete floor to a new chipboard floor.
Basically I've knocked through into an unused lean to and the plan is that this will now become the new downstairs WC. Given the difference in floor levels a suspended timber floor was created with 18mm P5 moisture resistant chipboard as the subfloor (as per building control officer guidance). I am looking at having the same flooring (possibly vinyl) go between the two rooms.
The room that I'm going from (utility room) has a solid concrete floor and I wanted to understand from people what's the best way to join them as there's a 1-2mm gap between the two. My main concern is that if I lay the same floor there will be some kind of cracking/tearing as this is effectively a 'weak spot'.
Do I fill the gap with some kind of screed?
Do I leave it as it's not enough to worry about?
Do I ditch the idea of 1 single continuous floor covering between the two rooms and install some kind of threshold between the two, effectively going over the top of the small gap?
Advise would be appreciated!
J
J
