I want to relocate my cooker control unit as my kitchen has moved several feet. my question is, am i right in believing i can use 10mm unisulated crimps with heat sleeve so that it dont need to be accessable?
also, after re- running the cable can i use junction box to split the cable to to have both appliances isolated.
I was going to split the cable, continuing with 10mm to a CCU to the hob
and the other cable in 1.5mm or 2.5mm to Fused switch to the cooker.
what rating will the fuse ant main consumer unit need to be? and what size fuse on the fused swith for cooker ?
Thanks for any help.
