I am replacing a laminate worktop on existing cabinet units. There are three sections - 3 sides of a rectangle bounded at each end by walls. Centre wall is 4.6 metres long. Worktop is to be fabricated offsite by local worktop factory. No problem with first join but second has to be made in situ on top of the base units. There is access underneath for the joining bolts since the join is next to a 15cm gap for trays and towel holder. Also no restrictions in applying the adhesive to the surfaces to be joined. Splash backs are to be installed at each end so I can hide a small gap at both walls (6mm in total???) to try and make space for the last section to be positioned and aligned.
Does this plan sound feasible or is it likely to end in tears? Any practical experience on the minimum gap needed to carry out this operation?
Thanks for any help.
