joist hangers at an angle on treehouse floor
28 Aug 2014
Sheffield
I'm building a treehouse (or a shed/cabin within the trees as its not supported by the trees).
and my floor joists are at different angles.
Joists are treated 6x2.
I've already got 3 screws at the end 90mm x 5mm and 85mm x 6mm
(the hangers is an after thought, hence why i started with some 2x3 and 2x4 noggins, as I didn't realise I needed hangers at the time)
what kind of joist hangers do i need for this?
will something like this work - adjustable joist hangers? can i bend the wings to suit my angle?
as you can see above my angles vary, maybe from 45 to 110 degrees.
I also now realise that the joists are too far apart so I am going to add some more. I thought i could span every 2 feet and add more noggins but now i believe they should be every 400mm on center. And some are painted with shed wood preserve but it's too cold to finish the rest at the moment.
thanks
Update. I've just been advised that the above joist hangers are not suitable and I need skewable hangers
