Hi all. I am nothing more than a novice. Recently ripped out my Victorian wooden floor. The air vent was blocked and wall plates and joist ends all rotten. Now, after much humming and thinking I have fitted wall plates, 4" x 2" treated timber ready to take joist hangers. I could have used the previous method where the joists rested on a wooden sleeper which rested on the sleeper walls, see photo for sleeper wallsView media item 67904 ...but decided to use timber to timber joist hangers instead as this gets the timber off the damp floor. The new wall plates have been bolted to the wall and are level and I have bought timber to timber hangers in photo. View media item 67905 The joists are 4" x 2" treated also, set at 400mm centres, ready to take flooring T&G Chipboard.
Bearing in mind the floor will now be better ventilated but probably slightly damp as it is above bare earth...would it be better to fix hangers with screws...I have zinc yellow passivated 8's x 40mm...or use square twist nails.
The wall plate spans a wall 3.5m wide and joist span end to end is 3.6m with a sleeper wall in centre for support at 1.8m.
Will my method work...Or have I not used the best method for the floor at all?
The floor will be 18mm T&G Flooring chipboard, then underlay for laminate flooring. Would it still be an idea to add between joist insulation?
I look forward to your advice people.
