Afternoon,
I've purchased a Tuin Laura log cabin (4.3m^2) https://www.tuin.co.uk/laula-log-cabin-DG.html, and will be going with a wood frame foundation to avoid the need for a slab - the ground is fairly uneven.
To keep the height down, I'd like to use 75x100mm joists, but trying to figure out the distance between supports that will require. The standard span tables are geared around floors where the weight is spread - for this, the perimeter joists will be taking all the weight.
Anyone got any guidance on what spacing I should use ? And is 100mm going to be pushing it - should I be looking at more like 150mm ?
