It sounds as if the whole supply is protected by a 13A fuse, why you would have a consumer unit I don't know, seems over kill if all fed from 13A fuse. But to extend metal conduit is not easy, and also not easy to keep water proof, plastic is easy enough to extend but in both cases whole idea of conduit is you can draw in new cables, so I would not attempt to join them I would use new. It does not sound like a professional job, OK maybe the guy had a spare consumer unit knocking around, but if supplying from 13A fuse in a fused connection unit, then I would use a second FCU with switch to fuse down further for lights, not a consumer unit.
