Ka aircon goes into reverse?
8 May 2010
New South Wales
Ka aircon seems to go reverse (reverse cycle) when turned off and on (like when stalled) or a short stop at a shop. The heat that comes out is over 50deg c even if the car is cold. Anyone experienced this or know what is wrong? An aircon mechanic reckoned it cant happen because of a one way valve in the line.
I am considering pinching the heater pipe to see if no water flow would prove it is the aircon.
I would think its more likely to be a fault in the heater control system which is letting hot air in when it shouldn't.
Peter
Theoretically it can't happen because the condenser would have to become the evaporator and vice versa which is do able in a heat pump designed for it but very strange in a car situation.
Peter
