- Joined
- 27 Apr 2008
- Messages
- 10,184
- Reaction score
- 1,166
- Country
HI, I have a 2016/17 Ford KA+ and after letting the tank get low has suddenly started with very rough running.
Using a Bluetooth ODB adapter I have obtained the codes:
P0013 (Camshaft Position → Open/Short OCV → Bank 1)
P0201 (Injector circuit cylinder 1)
P0301 (Cylinder 1 misfire detected).
Weird how I get the top one at the same time as the injector circuit one.
I have cleaned it with isopropyl cleaner (brake cleaner) but it's not that dirty as the oil has only been in just over 1 year/6000 miles. = no effect.
I have another KA+ so have tried swapping parts, when I swap the camshaft actuator and clear the faults, this one does not return - put the old one back and it soon returns. The resistance of it is 8.4 ohms - same as the other one.
However when swapped it still ran rough.
Q: What does this actually do?
What is the effect of it going faulty?
EDIT: Explained well here:
For the injectors, I have tried swapping one from the wifes car and it had little effect - still ran bad, this was a mistake to do as it took ages to get the wifes injectors back in, mine were easy. Had to wipe oil around the cylinder block holes and the injector seal to get them in.
On mine, I have tried a trick I saw on Youtube of putting a 12v bulb in the plug, on cylinders 1-3 it flashed mid brightness.
On cylinder 1 if was almost constant and a lot brighter. I guess I should actually measure the voltage.
Given that the bulb light this tells me the cable is OK & not O/C.
Now I'm at a loss what to do next, I'd rather not take it back to Ford (not under warranty) as it will undoubtedly cost me a hell of a lot.
I have ordered a used injector train set so I can replace the one in cylinder one (although I'm not sure it is this).
Given both faults happen at the same time I'm wondering if it is the BCU/ECM and that I'm sure will cost an arm and a leg.
Although they are available on the bay, I just need to know exactly what the part is - first thing to do is identify then find it?
Any helpful suggestions appreciated
Thanks.
I shall go try swap spark plugs now, see what effect that has.
Thanks.
