Kango 950
29 Jul 2006
Where do I grease my Kango 950 which no longer hammers and I led to believe may be due to loss of or lack of grease? :) :D
Is that the old Kango 950? Like this....
Might be more than grease you need.
Milwaukee build these now. :D
Hi Norcon,
Yes thats the one. Very little use only really blunted one chisel!! It has stood for ages or should I say maybe 5 years. It sounds like its "hammering" and vibrates a bit. The piston is all attached and the barrel I assume it slides in is NOW free although it was stuck.
Regards jddevel :D
Put it in for a general service or you'll probably ruin it.
Bet they are a fortune to replace.
Common problem with old Kangos.
Once warm they are ok. Somehow when cold the tool does not connect with the striker.
Use some oil first then put a blob of grease on the end of the tool before inserting it (ooer missus!).
Whilst grateful for your advice Joe90 I`m afraid I`m at the cynical age where I don`t trust so called service engineers. Having built houses, restored classic cars I`m afraid I take the attitude that there is no such thing as "can`t" Don`t know how or phy :D sically unable to are my views. So asking where the grease goes comes under the heading "don`t know how" So ask!.
With regard to Nosealls` remarks appreciated but I believe perhaps a "top up" of Kango grease may be required from what I`ve discovered on the net. But where to put it????
