We are planning a new kitchen.
I would like to know if a good joiner can be expected to cut a pre assembled unit ie. howdens to incorporate boxed pipes for example.
We have the water pipes running ina box where two of the walls meet.
Also the same question applies to the stoptap. Is it quite common to cut holes in the units to accomodate the stop tap?
I have had a go at designing the layout and for one of the runs there
is a gap between the end of the unit and the wall ie. about 5cm. Are end panels used to fix this sort of issue?
Also what are the people's experiences in terms of supplier faults with the major supplier ie. howdens ikea b&q magnet. Which do you think provide the best customer service (regardless of quality)?
Thank you
Thank you
