Kitchen: Fused Spurs v Switched 13A Sockets
3 Aug 2005
Surrey Hills
It was suggested to me that I could reduce the number of faceplates visible - which can make kitchen look cluttered - by using switched 13A sockets (within adjacent kitchen units) rather than fused spurs (where practical). e.g. for D/W, Fridge, Extractor
Is this a good idea? Are there notable any disadvantages?
Thanks.
You could reduce the number of faceplates by not having them.
It's up to you.
You don't need nor have to have Fused Connection Units.
There will be a fuse in the plug so a second one is not necessary and a switch is not really necessary either. You can remove the plug.
Certainly a plug socket in the cupboard next to appliance is an excellent way forward.
What do you do with rear of cupboards though if new
If you put socket in cabinet: Do you use surface mounted boxes on the inside of the cabinets? And have a hole for the plug to come through from the back?
Of course.
It depends.
Some kitchen units have the back panel right at the back, some leave a small gap.
A socket in the wall would be better with a neat hole in the back panel. Surface mounted or flush mounted depending on the above.
Then you would have a hole for the plug in the unit's side panel.
You may think holes are undesirable but neatly cut they are hardly noticed.
Use a hole cutter - not a hammer as some do.
Thanks, so ideally flush mounted socket in the wall behind an adjacent cabinet with a hole in the back for access?
