kitchen hood on top floor needs an open window to work
18 Aug 2011
I've had a kitchen hood installed, by a non professional.
When the hood is on, the air appears to blow back through the walls(electrical sockets). I'm told that this is common if you live on the top floor of an appartment, which I do. The solution is further suggested that I should open a window, when its on.
I understand the open window suction part, but is this really 'the' solution? the idea with having a kitchen hood, is not to have to open the window in the first place.
Is there a better solution?
Ha ha hilarious :p
Your 'fitter' hasn't vented the thing to the outside then, but maybe into the cavity?
John :)
This is a common problem when fitted by an idiot, does not matter which floor you are on, though you could end up on the floor if the damp air makes your sockets live to touch. :!: :!: :!:
They can normally be set to just circulate the air through a filter rather than vent to outside. If yours is not venting correctly you can try it on this unvented setting which should be described in the instruction book.
thanks for the feedback. Time to call in a pro to install it.
