Hi there hoping someone can help
I recently had installed a brand new combi-boiler system and radiators.
System Configuration:
Boiler
Make: Worcester-Bosch
Model: Greenstar 24i Junior
Radiators
Make: Stelrad
Model: Compact
TVR's fitted on all radiators including the affected one, honeywell room thermstat and the Worcester-bosch digital programmer is installed in the boiler.
All the radiators are fine expect the one in the kitchen. We have had the system in just over a week and made a number of calls to the installation team with very little joy.
The kitchen radiator is causing a problem. The TVR is on 5 (max.) and I have bled it. It gets hot when the system is first on, but after about an hour it goes cold, as do the pipes leading up to it. I bleed it when this happens - water comes straight out, only for it to get hot again then go cold after about an hour.
I contacted the installers, and they said, is your TVR fully open - which it is, is your boiler set to Max for central heating - which it is, and is your room themostat up past 22 degrees - which it is.
I have explained to them the above, but they have said let the system settle in or bleed the radiator - is this the case?
Would appreciate any thoughts on this.
Boiler
Radiators
Make: Stelrad
Model: Compact
