If you are absolutely certain that it is TN-S (and not TN-C-S) then that makes a lot of difference in terms of the regs, since it would mean that 6mm² cable (with or without joins) would almost certainly be adequate for a main bonding conductor, whereas the minimum would be 10mm² if it were TN-C-S (PME).It is a TN-S supply. I am not sure if this makes much different as I assume a fault can cause can cause a large amount of current to flow through the earth cable regardless of what the appliance consumes, but we have no electric cooker or shower.
Kind Regards, John
