kitchen sink pipe overflows
24 Oct 2020
Any help on this appreciated. Nothing is too obvious - I know nothing about plumbing.
Under the kitchen sink. When a lot of water goes down the plughole (e.g. sink full of water and then released), there is a pipe underneath which overflows. Look at 19 seconds in on
this video I made.
(Ignore the leak from right under the plug for now). Should that grey tee pipe at the back have an open part? Is it as simple as getting some sort of stopper for that? Because surely the water should just flow down under gravity anyhow
Thanks in advance for any suggestions.
John
That's a double sink pipe.
Have you got a double sink?
If so, you need a strainer for the other bowl, connected to that open grey pipe.
If you only have a single bowl sink, get rid of the grey pipe and connect strainer to mini stack (white pipe)
As said, no. What you have there is a 'waste kit' for a 1 1/2 bowl sink, (i.e. with 2 plugholes). Assuming you dont have a 1 1/2 bowl sink then you need to remove the grey part, fit a new waste, (https://www.screwfix.com/p/stainless-steel-strainer-waste-1-bowl-90mm/9411k). Then refit the trap to this, and reconnect the trap outlet to the existing outlet with a section of pipe and bend(s) to suit.
Thanks very much! Quick question, if you don't mind..
I do only have a sink with one plughole, yes. Instead of having the trap right under the waste bowl, do you think I could keep the grey horizontal pipe? So, keep the trap where it is. And then, because the grey corner bit which water flows out of is detachable, just replace that - with a closed corner bend piece. Do they have parts like that? Cheers
The grey waste setup comes as a complete kit, you may be able to get spares possibly, but normally in the event of an issue, it's easier to replace the lot. I am not aware of a bend that would be suitable to replace the Tee with the missing piece sadly, McAlpine do caps for waste pipes but I dont think they're the same thread as you've got.
Usually those grey pipes that come with sinks go straight in the bin for me.
A mcalpine strainer and fittings costs peanuts but never leak in my experience.
One of these will screw on, it's the same thread as the trap on the other end of the grey tee.
https://www.ebay.co.uk/itm/McALPINE-1-p-BLANKING-CAP-WITH-NUT-T23-/293588382866
If the grey horizontal really runs uphill you will be changing it soon anyway.
Do it once, do it right.
Get rid of grey pipe and grey strainer and use mcalpine fittings.
Then you won't have to worry about it until you change your kitchen.
that's a great help, cheers guys
