Kitchen tap replacement
1 Dec 2008
Surrey
I need to replace a leaking kitchen tap on a stainless steel unit. The fitting has a large bolt on the underside (see pics in DicksDIY album) rather than the nut I was expecting. Are taps still available with this fitting?
The piccies look like the same fitting as most monobloc mxers, except the manufacturer chose to fit a sleeve nut to the fixing stud instead of a conventional plain hexagonal nut.
The sleeve nut at least makes it a bit more get-at-able without needing to resort to long box spanners etc.
