Kitchen Taps, Combi Boiler, no stop cock or any isolation
26 Feb 2008
Shropshire
Hi, Just moved into new home, Kitchen taps are shot and need changing. There is an on-demand combi boiler and I just cannot locate a stop-cock and of course no in-line isolators to taps. Not normally a problem for me however I've not had much experience with combi's.
Is it as simple as isolating the MAINS water outside/road then isolating the Electric/MCB to boiler thus open/drain the hot & cold taps/lines and change taps, job done?????????
or will I get covered in water and die?
Regards
Many thanks
Andy
At the end of the day you just need to switch the mains water off (so you don't get wet). When I switch the mains water off I always switch the boiler off but not 100% sure I have to?
Ok Cheers for that, Fitting the taps ain't going to be a problem, I just don't want to bugger around draining the system.
My only other concern is WHY there are 2 drain cocks that Tee-off the HOT & COLD 15mm pipes just below the kitchen taps (not a the lowest point either) is this normal or am I dealing with a cowboy installation?
Regards
Andy
When water turned off it is best to always turn of electric to boiler.
Whilst you have the mains water off, why not cut a new internal stopcock into your rising main?
